メインコンテンツにスキップ
Disassembling Canon PowerShot SD850 IS Case Removal
必要な工具と部品
  1. Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 手順 1、 3の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 手順 1、 3の画像 2 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: 手順 1、 3の画像 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 2、 2の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal: 手順 2、 2の画像 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Disassembling Canon PowerShot SD850 IS Case Removal, Case: 手順 3、 2の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal, Case: 手順 3、 2の画像 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 4、 3の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal: 手順 4、 3の画像 2 Disassembling Canon PowerShot SD850 IS Case Removal: 手順 4、 3の画像 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 5、 2の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal: 手順 5、 2の画像 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 6、 2の画像 1 Disassembling Canon PowerShot SD850 IS Case Removal: 手順 6、 2の画像 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 7、 1の画像 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Disassembling Canon PowerShot SD850 IS Case Removal: 手順 8、 1の画像 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Peter Tran
メンバー登録日: 10/06/10
225 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G7
6 メンバー
7のガイドは作成済み
コメント 1 件
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 23
今までの合計 4,269
