Follow the small data cable to where it connects to the camera.
Lift the back white portion to unlock the cable.
The cable should easily slide out.
The connector is very fragile. Use caution when lifting the lock.
Gently lift LCD display off.
There will be two data cables still attached to the camera. Do not break them.
There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
Follow the larger cable to where it connects to the camera.
Lift the front black portion of the connector to unlock the data cable.
To remove the LCD, peel the larger data cable off from the frame.
The LCD is glued by its data cable to the back of the LCD frame.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
