メインコンテンツにスキップ
Disassembling Canon PowerShot SD800 IS LCD Display
必要な工具と部品
  1. Disassembling Canon PowerShot SD800 IS LCD Display, Back Cover: 手順 1、 1の画像 1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 2、 1の画像 1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 3、 1の画像 1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 4、 1の画像 1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Assembly: 手順 5、 1の画像 1
    • Remove 2 2.4mm screws on bottom.
  6. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 6、 1の画像 1
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 7、 1の画像 1
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 8、 1の画像 1
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
  9. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Display: 手順 9、 1の画像 1
    • Pry the LCD display out from the four metal clamps.
  10. Disassembling Canon PowerShot SD800 IS LCD Display: 手順 10、 1の画像 1
    • To remove the LCD, peel the larger data cable off from the frame.
    • The LCD is glued by its data cable to the back of the LCD frame.
終わりに
作成者
3人の作成者と共同で作成されました。
Jeremy Rabaino
メンバー登録日: 10/10/10
135 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G9
5 メンバー
13のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 2,846
