メインコンテンツにスキップ
Disassembling Canon PowerShot G16
必要な工具と部品
  1. Disassembling Canon PowerShot G16, Battery: 手順 1、 3の画像 1 Disassembling Canon PowerShot G16, Battery: 手順 1、 3の画像 2 Disassembling Canon PowerShot G16, Battery: 手順 1、 3の画像 3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Disassembling Canon PowerShot G16: 手順 2、 3の画像 1 Disassembling Canon PowerShot G16: 手順 2、 3の画像 2 Disassembling Canon PowerShot G16: 手順 2、 3の画像 3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
    If I cannot open card/Batt. Open how??
    Jose Ocasio - 返信
  3. Disassembling Canon PowerShot G16, Button Circuit Board: 手順 3、 3の画像 1 Disassembling Canon PowerShot G16, Button Circuit Board: 手順 3、 3の画像 2 Disassembling Canon PowerShot G16, Button Circuit Board: 手順 3、 3の画像 3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Disassembling Canon PowerShot G16: 手順 4、 1の画像 1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Disassembling Canon PowerShot G16: 手順 5、 1の画像 1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Disassembling Canon PowerShot G16: 手順 6、 1の画像 1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Disassembling Canon PowerShot G16: 手順 7、 1の画像 1
    • Open the port cover by lifting up the tab with your finger and remove the 7.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Disassembling Canon PowerShot G16: 手順 8、 2の画像 1 Disassembling Canon PowerShot G16: 手順 8、 2の画像 2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Disassembling Canon PowerShot G16: 手順 9、 1の画像 1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Disassembling Canon PowerShot G16: 手順 10、 2の画像 1 Disassembling Canon PowerShot G16: 手順 10、 2の画像 2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Disassembling Canon PowerShot G16: 手順 11、 1の画像 1
    この手順で使用する道具:
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
    This is not completely correct. In order to pull the connector down without force, the little grey tap on the top of the connectorbox has to be flipped up.
    This particular step cost me the connection to the button curcuit board. I would be grateful for an indication of where I can buy a replacement. Thanks.
    Martin Salamon - 返信
    You saved my connection. Thank you. iFixit... I'm somewhat disappointed these steps haven't been corrected.
    It's worth noting that I had no luck with tweezers when attempting to remove the ribbon cable. The correct procedure would be to carefully lift the plastic clip with an iFixit spudger and then continue to step 12. The ribbon cable will pull out gently without any other coercion.
    Phil Howard - 返信
    The clip is a red/terracotta colour, this should be lifted like a lid (the hinge is mounted in the grey housing). The connector should be pulled downward as described. This should definitely be corrected. Thanks for the comments to assist. I added this for extra clarity on the colours only.
    Jon Mayers - 返信
    just destroyed it!, thanks for nothing...
    karollus invincibullus - 返信
    Lool, just noticed on the pictures you destroyed your connector as well. Good for you for posting faulty guide.
  12. Disassembling Canon PowerShot G16: 手順 12、 1の画像 1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Disassembling Canon PowerShot G16: 手順 13、 1の画像 1
    • Lift the button circuit board away from the camera.
  14. Disassembling Canon PowerShot G16, LCD: 手順 14、 3の画像 1 Disassembling Canon PowerShot G16, LCD: 手順 14、 3の画像 2 Disassembling Canon PowerShot G16, LCD: 手順 14、 3の画像 3
    • Do not pull the connector upwards as doing so may harm the connector housing.
    • Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
    • Gently pull the connector straight out of the housing with your fingers.
  15. Disassembling Canon PowerShot G16: 手順 15、 2の画像 1 Disassembling Canon PowerShot G16: 手順 15、 2の画像 2
    • Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
    Be careful with this step. I broke the black connector off the motherboard for the small ribbon cable. It is very fragile. You might want to push down on the black connector to hold it in place while gently pulling the ribbon to the right to extract it from the connector. Don’t let the black connect pull up or twist.
    Jeffrey Watkins - 返信
  16. Disassembling Canon PowerShot G16: 手順 16、 1の画像 1
    • Be careful of the copper plate that may fall out once you lift the LCD screen away.
    • Gently lift the LCD away from the camera housing.
  17. Disassembling Canon PowerShot G16, Motherboard: 手順 17、 2の画像 1 Disassembling Canon PowerShot G16, Motherboard: 手順 17、 2の画像 2
    • Be careful not to bend the EMI shield.
    • Lift and remove the copper EMI shield.
    the screw in the upper right corner disappears magically between the two photos in this step ;) .
    ma.so - 返信
  18. Disassembling Canon PowerShot G16: 手順 18、 1の画像 1
    • Reorient the camera so that you are looking at the front.
    • Remove the 2.8 mm screw right above the screw holding the lens on using a Phillips #00 screwdriver.
    • Remove the 3.3 mm black screw to the left of the front viewfinder using a Phillips #000 screwdriver.
  19. Disassembling Canon PowerShot G16: 手順 19、 1の画像 1
    • Remove the 6.8 mm screw to the left of the rear viewfinder using a Phillips #00 screwdriver.
    • Remove the 5.2 mm screw to the right of the rear viewfinder using a Phillips #00 screwdriver.
    Somewhere between this step, and Step 21 the screw in the top right (right and up slightly of the orange circled 5.2mm screw) is removed. Suggest doing it here! Same with the one immediately to the right of that.
    Phil Howard - 返信
    Perfect Comment of Phil Howard! In this moment is necessary remove other screw positioned upper-right
    alepav78 - 返信
  20. Disassembling Canon PowerShot G16: 手順 20、 2の画像 1 Disassembling Canon PowerShot G16: 手順 20、 2の画像 2
    • Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
    • Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
    you don’t have to remove the 2.3mm screw in this step, it’s just connected to the top cover
    ma.so - 返信
  21. Disassembling Canon PowerShot G16: 手順 21、 2の画像 1 Disassembling Canon PowerShot G16: 手順 21、 2の画像 2
    • Reorient the camera so that you are looking at the back of the camera.
    • Remove the rear viewfinder casing by firmly gripping it and pulling it out bottom first.
    • When reassembling, make sure that the viewfinder is fitted correctly beneath the top cover.
  22. Disassembling Canon PowerShot G16: 手順 22、 1の画像 1
    • Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
    • Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
    It’s necessary remove olso other little screw positioned on the orange screw ;)
    alepav78 - 返信
    The right-most screw encircled in green requires a smaller driver than the rest of the screws in this step.
    Brian Sweeney - 返信
  23. Disassembling Canon PowerShot G16: 手順 23、 1の画像 1
    • Remove the 2.7 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
  24. Disassembling Canon PowerShot G16: 手順 24、 1の画像 1
    • Reorient the camera so that you are looking at the side with the black felt circle.
    • Use caution around this black felt covered circle that is right below the screw to be removed. This is the speaker and can easily be damaged if pressed too hard or poked with a screwdriver.
    • Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
  25. Disassembling Canon PowerShot G16: 手順 25、 1の画像 1
    • Remove the metal casing from the back by lifting it away from the camera.
  26. Disassembling Canon PowerShot G16: 手順 26、 1の画像 1
    • Disconnect the cable on the top of the motherboard by lifting it up vertically using a plastic opening tool.
  27. Disassembling Canon PowerShot G16: 手順 27、 2の画像 1 Disassembling Canon PowerShot G16: 手順 27、 2の画像 2
    • Disconnect the cable on the back of the camera to the left of the viewfinder by lifting it up vertically using a plastic opening tool.
  28. Disassembling Canon PowerShot G16: 手順 28、 2の画像 1 Disassembling Canon PowerShot G16: 手順 28、 2の画像 2
    • Remove the top portion of the casing by firmly grasping it and pulling it upward to lift it off.
    • Some force may be required, but be careful to not bend either side of the top casing up too much or you will damage it.
    At this point the tiny little ribbon cable and flat-flex with two diodes on it (face sensor?) may still be attached to the right of the viewfinder lens. It may just be caught on the two locating pegs. Pull it gently upwards before removing the top.
    Phil Howard - 返信
    Same precisation of Phil Howard! Please attention at that flat-flex, raise flat before remove machine top!!!!!
    alepav78 - 返信
  29. Disassembling Canon PowerShot G16: 手順 29、 3の画像 1 Disassembling Canon PowerShot G16: 手順 29、 3の画像 2 Disassembling Canon PowerShot G16: 手順 29、 3の画像 3
    • Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
    • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged if pinched. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Disconnect the two cable ribbons by pulling them straight out.
  30. Disassembling Canon PowerShot G16: 手順 30、 2の画像 1 Disassembling Canon PowerShot G16: 手順 30、 2の画像 2
    • Disconnect the lens cable from the motherboard by lifting it up vertically from the motherboard using a plastic opening tool.
    Must remove 2 screw:
    1) bottom-left (little head, long shaft)
    "2) upper-left (big head, short shaft)
    for remove motherboard
    alepav78 - 返信
  31. Disassembling Canon PowerShot G16: 手順 31、 2の画像 1 Disassembling Canon PowerShot G16: 手順 31、 2の画像 2
    この手順で使用する道具:
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
    • Remove both Screws on the bottom side of the motherboard
  32. Disassembling Canon PowerShot G16: 手順 32、 1の画像 1
    • Lift the motherboard out of the camera.
    It's missing the step to remove two screw that fixes the motherboard
    hugo.marcondes - 返信
    Probably would be helpful to remove the memory card before doing this step. I’m not sure that was suggested previously.
    Brian Sweeney - 返信
    Also, just opening the battery compartment door may be helpful in removing the main board.
    Brian Sweeney - 返信
    You can clearly see that one socket is missing at the top of the plate. It was destroyed some steps earlier.
  33. Disassembling Canon PowerShot G16, Lens: 手順 33、 1の画像 1
    • Reorient the camera so that black lens cover is facing you with viewfinder on top.
    • Remove the four 5.3 mm screws around the lens using a Phillips #00 screwdriver.
    • Remove the 3.8 mm screw above the lens using a Phillips #00 screwdriver.
  34. Disassembling Canon PowerShot G16: 手順 34、 1の画像 1
    • Remove the black plastic cover surrounding the lens by gripping and lifting upwards.
  35. Disassembling Canon PowerShot G16: 手順 35、 1の画像 1
    • Remove the black 3.8 mm screw on the far left side using a Phillips #000 screwdriver.
  36. Disassembling Canon PowerShot G16: 手順 36、 2の画像 1 Disassembling Canon PowerShot G16: 手順 36、 2の画像 2
    • Grip the left and right halves of the camera and wiggle them apart.
    You can see that a small screw is missing over the lens. It must have been removed between steps. poor quality.
  37. Disassembling Canon PowerShot G16: 手順 37、 1の画像 1
    • Use caution around the black felt covered circle. This is the speaker and can easily be damaged.
    • Pick up the half of the camera that contains the lens.
    • Remove top 4 mm screw from the strap holder using a Phillips #00 screwdriver.
    • Remove the middle 3.8 mm screw next to the left speaker using a Phillips #00 screwdriver.
  38. Disassembling Canon PowerShot G16: 手順 38、 1の画像 1
    • Remove the cable strap bracket by lifting it away.
  39. Disassembling Canon PowerShot G16: 手順 39、 1の画像 1
    • Do not pull the connector upwards because doing so may harm the connector housing.
    • Be carful not to pinch the cable while pulling it out.
    • Disconnect the cable in the top left by pulling it straight out of its connector.
  40. Disassembling Canon PowerShot G16: 手順 40、 2の画像 1 Disassembling Canon PowerShot G16: 手順 40、 2の画像 2
    • Lift the metal frame away from the lens.
    • After you remove the metal frame, the lens will be by itself.
  41. Disassembling Canon PowerShot G16, Disassembling Canon PowerShot G16: 手順 41、 1の画像 1
    • Remove the two 2.8 mm screws on the top of the lens assembly near the viewfinder using a Phillips #00 screwdriver.
  42. Disassembling Canon PowerShot G16: 手順 42、 2の画像 1 Disassembling Canon PowerShot G16: 手順 42、 2の画像 2
    • Lift the viewfinder away from the lens assembly.
  43. Disassembling Canon PowerShot G16: 手順 43、 2の画像 1 Disassembling Canon PowerShot G16: 手順 43、 2の画像 2
    • Grab the metal frame with the flash assembly that was removed from around the lens assembly.
    • Remove the 2 mm screw on the circuit board using a Phillips #00 screwdriver.
    • Lift and remove the circuit board from the flash assembly.
  44. Disassembling Canon PowerShot G16: 手順 44、 1の画像 1
    • Here our journey ends. Now the journey of reassembly begins.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jonathan Harger
メンバー登録日: 01/11/16
1,258 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 70-6, Forte Winter 2016 Cal Poly, Team 70-6, Forte Winter 2016人のメンバー
CPSU-FORTE-W16S70G6
4 メンバー
7のガイドは作成済み
6 Guide Comments
Excellent guide, thank you so much. My camera has an intermittent fault so I should now be able to save a lot of time and money by trying myself to find the possible loose connection inside.
Aspivenin - 返信
Moisture ring on inside of lens. No way to clean this off. Also, shutter release button gone: no replacement found anywhere.
ewchnsw - 返信
Thank you SO MUCH. One of our company cameras, a PowerShot G15 had a dead display. A person on the Canonforum…
https://community.usa.canon.com/t5/Power...
…recommended disassembling the camera via iFixit instructions for the G16 (slightly different than the G15), unplugging the display, and plugging it back in again…WHICH WORKED. Did the whole thing in about 30 minutes. Awesome. Saved us a lot of money. Very grateful.
Scott Morrison - 返信
Hi,
Could you describe how to disassemble and assemble the lens curtain - th esix leaves and two springs that cover the lens when the lens is retracted into the camera? I’ve tried to assemble it, but end up with the mechanism only closing 2/3rd way. It opens fine. I want to replace my scratched lens with an unscratched one, but the new one is the one with the curtain problem. Thank you!
H Stahl - 返信
i have the same question...
SebastianM -
Thank you very much for this great work. I was able to fix my G16 from a lens failure.
Luca Lorenzi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 65
今までの合計 11,636
