メインコンテンツにスキップ
Disassembling Canon Pixma MP480 Rear and Side Panel
必要な工具と部品
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 手順 1、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: 手順 1、 2の画像 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 2、 1の画像 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
    "quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
    Perhaps Fuzz - 返信
    Thank you, Perhaps Fuzz. Thank you.
    Marji Zintz -
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 3、 1の画像 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 4、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 4、 2の画像 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 5、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 5、 2の画像 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 6、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 6、 2の画像 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 7、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 7、 2の画像 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 8、 2の画像 1 Disassembling Canon Pixma MP480 Rear and Side Panel: 手順 8、 2の画像 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
終わりに
6 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Kevin Cole
メンバー登録日: 01/17/13
116 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G41
4 メンバー
6のガイドは作成済み
2 件のコメント
Where is the rest of disassembly?
bill roberts - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 30
今までの合計 21,156
