メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to replace a damaged front cover or to access the inner parts of the camera.
パーツ
パーツは指定されていません。
  1. Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Remove three medium length screws from the bottom of the camera
    • Remove three medium length screws from the bottom of the camera
  4. Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
終わりに
ある他の人がこのガイドを完成しました。
Daniel Bussone
メンバー登録日: 2011年01月28日
1,239 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G41
2 メンバー
21のガイドは作成済み
2 件のコメント
This should be labelled: Easy.
tjt263 - 返信
Okay, there are several steps missing.
tjt263 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 19
今までの合計 4,888
