はじめに
The Black and Decker 3-Cup Rice Cooker contains a brass plate that prevents access to the inside of the device. The internal portion of the device contains wire junctions that prevent access to the internal parts. In this guide we will remove both.
必要な工具と部品
Turn the device upside-down, so that the four legs of the device point upwards.
Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
Unscrew the screw at the junction near the opposite side of the device from the front panel.
Label each of the two wires at this junction with a single color of tape.
Unscrew the screw at the junction just clockwise from the button panel.
Label the three wires of this junction with tape of a second color.
Unscrew the screw from the wire junction just behind the front panel.
Label the three wires at this junction with a third color of tape.
