はじめに
How to disassemble the charger unit.
  1. Slide the plug to release from the transformer unit
    • Slide the plug to release from the transformer unit
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
    • Slip a knife blade into the seam on one of the long edges. It should go in a fair way. Lever the lid upwards. It requires quite a bit of force to release. Be careful as the outer casing is flimsy and it will be deformed.
  4. Once the lid comes off you can slide out the internals.
    • Once the lid comes off you can slide out the internals.
まとめ
2 の人々がこのガイドを完成させました。
ehfb
メンバー登録日: 2015年02月17日
61 ポイント
1ガイドが承認済み
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 33
今までの合計 3,829
