メインコンテンツにスキップ
Disassembling Apple IIc Cover
必要な工具と部品
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 手順 1、 2の画像 1 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 手順 1、 2の画像 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Disassembling Apple IIc Cover: 手順 2、 2の画像 1 Disassembling Apple IIc Cover: 手順 2、 2の画像 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Disassembling Apple IIc Cover: 手順 3、 2の画像 1 Disassembling Apple IIc Cover: 手順 3、 2の画像 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    This step is wrong. The ports cover should be removed with a plastic disassembly tool first. Failure to do this will lead to a set of broken plastic hooks.
    cybernesto - 返信
  4. Disassembling Apple IIc Cover: 手順 4、 2の画像 1 Disassembling Apple IIc Cover: 手順 4、 2の画像 2
    • Lift the handle straight up to remove.
終わりに
10 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Alexandria Weinberg
メンバー登録日: 10/06/11
601 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G23
4 メンバー
13のガイドは作成済み
3 件のコメント
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - 返信
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III -
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 114
今までの合計 9,660
