メインコンテンツにスキップ
Disassembling Apple AirPort Extreme Base Station Model A1034
必要な工具と部品
  1. Disassembling Apple AirPort Extreme Base Station Model A1034, Disassembling Apple AirPort Extreme Base Station Model A1034: 手順 1、 1の画像 1
    • Remove the three 5mm T7 Torx screws from the back panel.
  2. Disassembling Apple AirPort Extreme Base Station Model A1034: 手順 2、 1の画像 1
    • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
  3. Disassembling Apple AirPort Extreme Base Station Model A1034: 手順 3、 1の画像 1
    • Separate the bottom and top casings.
  4. Disassembling Apple AirPort Extreme Base Station Model A1034: 手順 4、 2の画像 1 Disassembling Apple AirPort Extreme Base Station Model A1034: 手順 4、 2の画像 2
    • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
    • Remove the four screws from the metal casing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Michael Garcia
メンバー登録日: 10/12/11
411 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G15
3 メンバー
13のガイドは作成済み
コメント 1 件
Whoa, who’d have thought there was a hidden 5mm phillips under the serial number that does the trick? I’ve had this little beauty hanging around for decades, and my six year old started using it as a flying saucer with his lego creations, and it took me three months of pandemic before I picked up my screwdrivers and tried to take it apart so that he could really use it. For now it’s just empty, and he closes some figures in it with a rubber band and flies it around. Someday I’ll get that dremel i’ve wanted and make him some sort of hatch and latch for it, maybe add some lego baseplate bits to it or something, it can join the rebel alliance for reals.
bitfool - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 30
今までの合計 2,748
