メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling APEX AP-GS918 Screen
必要な工具と部品
  1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: 手順 1、 3の画像 1 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 手順 1、 3の画像 2 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 手順 1、 3の画像 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling APEX AP-GS918 Screen: 手順 2、 3の画像 1 Disassembling APEX AP-GS918 Screen: 手順 2、 3の画像 2 Disassembling APEX AP-GS918 Screen: 手順 2、 3の画像 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling APEX AP-GS918 Screen: 手順 3、 2の画像 1 Disassembling APEX AP-GS918 Screen: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling APEX AP-GS918 Screen, Battery: 手順 4、 2の画像 1 Disassembling APEX AP-GS918 Screen, Battery: 手順 4、 2の画像 2
    • Begin removing the black tape covering the motherboard inside the tablet.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling APEX AP-GS918 Screen: 手順 5、 1の画像 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    FixBotに聞いてみる
    コメントを追加
  6. Disassembling APEX AP-GS918 Screen: 手順 6、 2の画像 1 Disassembling APEX AP-GS918 Screen: 手順 6、 2の画像 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
    FixBotに聞いてみる
    コメントを追加
  7. Disassembling APEX AP-GS918 Screen, Screen: 手順 7、 2の画像 1 Disassembling APEX AP-GS918 Screen, Screen: 手順 7、 2の画像 2
    • The motherboard will need to be removed in order to access the screen.
    • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
    FixBotに聞いてみる
    コメントを追加
  8. Disassembling APEX AP-GS918 Screen: 手順 8、 2の画像 1 Disassembling APEX AP-GS918 Screen: 手順 8、 2の画像 2
    • To finish removing the motherboard you must release the two data cables holding the screen to it.
    • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
    • You can now remove the data cables from the slots and lift the motherboard out from the device.
    FixBotに聞いてみる
    コメントを追加
  9. Disassembling APEX AP-GS918 Screen: 手順 9、 2の画像 1 Disassembling APEX AP-GS918 Screen: 手順 9、 2の画像 2
    • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
    FixBotに聞いてみる
    コメントを追加
  10. Disassembling APEX AP-GS918 Screen: 手順 10、 1の画像 1
    • Pull the thin plastic screen casing apart and you can remove the damaged screen.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Megan Lozicki
メンバー登録日: 02/19/15
416 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G1
3 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 46
今までの合計 947
