はじめに
If your coffee is coming out slowly or has very little créma it might be time to clean your brewgroup.
必要な工具と部品
Remove the the brewgroup from the machine by simultaneously pressing the "Push" bar and pulling towards you.
Using your phillips screwdriver, remove the two screws holding the grey bracket and white hose in place.
The upper piston is held in place by four clips, two on each side. To remove it, place a screwdriver lengthwise across both clips on one side, and depress them while pushing down on the top of piston. That should loosen one side, then do the same for the other and the piston assembly should come loose.
Remove the piston gasket and clean any coffee from the channel it sits in.
The top strainer gets a bath in some degreasant. A tooth-brush can penetrate every pore of the strainer. Sometimes can help a tooth-pick. In some cases, a needle will help you too. Rinse with water.
Take a look at the strainer, hold it towards the window or some strong light. you should be able to look through every hole. Well done.
The top piston only fits right in one position, so look at the pictures ! In the white circle, you see the connecting for the valve. That part has to face towards the top.
On the second picture you see the notches, Both have to glide in the Piston holder.
On the third picture you see the clips. All 4 of them have to snap in correctly. No problem.
Be sure to check the correct position of the two small arrows on the turning part of the brewgroup. The arrows must exactly face to each other.
The first coffee should get poured in the drain because the first coffee will contain traces of the degreasant.
The next cup of coffee will be an aesthetic pleasure of aromes, flavor and well formed Crèma. Enjoy.
A simple cleaning can revitalize your espresso machine.
9 の人々がこのガイドを完成させました。
