メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disabling the touch function
必要な工具と部品
  1. Disabling the touch function, Disabling the touch function: 手順 1、 1の画像 1
    • First disconnect all the cables to avoid doing some damage to both player and yourself.
    FixBotに聞いてみる
    コメントを追加
  2. Disabling the touch function, Open the case: 手順 2、 3の画像 1 Disabling the touch function, Open the case: 手順 2、 3の画像 2 Disabling the touch function, Open the case: 手順 2、 3の画像 3
    • At the back of the Player you'll find 4 #2 Phillips screws.
    • Once undone you can slide the case ca. 1,5cm towards you.
    • Now carefully pull the sides of the cover away from the body and lift the cover up.
    FixBotに聞いてみる
    コメントを追加
  3. Disabling the touch function, Deactivate the touch: 手順 3、 1の画像 1
    • Now there are two possibilities:
    • Either you want to see everything and have some tools, then you can use step 4 and 5.
    • Or you don't, then you go to step 6.
    FixBotに聞いてみる
    コメントを追加
  4. Disabling the touch function, The scenic route 1/2: 手順 4、 3の画像 1 Disabling the touch function, The scenic route 1/2: 手順 4、 3の画像 2 Disabling the touch function, The scenic route 1/2: 手順 4、 3の画像 3
    • Just be sure, you have disconnected the white ribbon from the mainboard, so you wouldn't damage the connector while taking the front cover off.
    • Now you have to get the metal spudger and gently work you way below the clips on the side and loosen them.
    • Then the ones at the top but careful, there are two left and right of the disk tray looking a bit different and consisting entirely out of snappy plastic.
    • Now the front cover will tilt forward.
    • Either you take the lower clips of as well, but the entire cover might jump towards you (in this case you have to make sure again, the blue ribbon is disconnected) or you just work with the gap you just created.
    FixBotに聞いてみる
    コメントを追加
  5. Disabling the touch function, The scenic route 2/2: 手順 5、 3の画像 1 Disabling the touch function, The scenic route 2/2: 手順 5、 3の画像 2 Disabling the touch function, The scenic route 2/2: 手順 5、 3の画像 3
    • Now you can take the spudger and open the little black clip on the connector holding the brown touch sensor ribbon.
    • Then just pull the brown ribbon out carefully and you are done.
    FixBotに聞いてみる
    コメントを追加
  6. Disabling the touch function, The Shortcut: 手順 6、 1の画像 1
    • Get the spudger and lift the small black clip on the white connector where the brown touch control ribbon is connected to the board.
    • Gently pull the brown ribbon out of the clip.
    FixBotに聞いてみる
    コメントを追加
  7. Disabling the touch function, Reassemble everything: 手順 7、 1の画像 1
    • After you have worked the magic don't forget to reconnect the white ribbon.
    • Now twist the cover back on. Twist, because it might need some gentle force to get through the last couple of millimeters.
    • Now your HT-E5550 will no longer unwantedly cycle through the sources or open and close the disc tray. The downside is that the touch-controls won't work either.
    FixBotに聞いてみる
    コメントを追加
終わりに
Thank you for trying. I hope it helps you as much as the fix helped me.
キャンセル: このガイドを終了できませんでした。
14 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Karsten
メンバー登録日: 04/23/14
995 ポイント
3のガイドは作成済み
6件のガイドコメント
you are awesome my friend, thanks.
Sa Gi - 返信 共有
That issue has been annoying the crap out of me for months now. Fingers crossed this works, but so far so good….
Awesome instructions by the way (even if it doesn’t work)
William - 返信 共有
Super! Hat funktioniert, läuft auch beim HT-D5200 wie hier beschrieben einwandfrei.
Michael Gallob - 返信 共有
super du bist der beste
Reinhold Membarth - 返信 共有
Hallo, vor Jahren hatte ich das Problem mit dem HT E5500 Samsung mitgeteilt. Hatte mir dann einen neuen Blu ray Spieler gekauft.
Hatte die Anlage jetzt neu in Betrieb genommen, stört noch genauso, fährt die Schublade raus. Habe das Gerät geöffnet und das Kabel entfernt.
Mich wunderte es nicht, das die Platine Fehlfunktionen hatte.1. Sind auf die Platinenbahnen Papieraufkleber, diese können den Schutzlack angreifen und einen Übergangswiderstand auslösen. Der Schutzlack ist teilweise am pröseln, wirklich eine schlechte Qualität. Die Basisplatinen sehen gut aus. Aber bei den Displayplatinen hat man gepfuscht. Jürgen Löw
Jürgen Löw - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 57
今までの合計 15,315
