メインコンテンツにスキップ
Dis/assembling Eye/Pupil Camera Housing
必要な工具と部品
  1. Dis/assembling Eye/Pupil Camera Housing, Dis/assembling Eye/Pupil Camera Housing: 手順 1、 1の画像 1
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Dis/assembling Eye/Pupil Camera Housing: 手順 2、 1の画像 1
    • Remove 4 screws.
  3. Dis/assembling Eye/Pupil Camera Housing: 手順 3、 1の画像 1
    • Remove cover to get to the PCB underneath
  4. Dis/assembling Eye/Pupil Camera Housing: 手順 4、 1の画像 1
    • Remove two screws on the PCB.
  5. Dis/assembling Eye/Pupil Camera Housing: 手順 5、 1の画像 1
    • Remove PCB from the base plastic piece.
  6. Dis/assembling Eye/Pupil Camera Housing: 手順 6、 1の画像 1
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Dis/assembling Eye/Pupil Camera Housing: 手順 7、 1の画像 1
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Dis/assembling Eye/Pupil Camera Housing: 手順 8、 1の画像 1
    • Completed assembly of the eye camera.
  9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: 手順 9、 1の画像 1
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Dis/assembling Eye/Pupil Camera Housing: 手順 10、 1の画像 1
    • Remove the black frame on the front of the pupil camera.
  11. Dis/assembling Eye/Pupil Camera Housing: 手順 11、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 11、 2の画像 2
    • Once frame is taken off the front, two screws need to be removed.
  12. Dis/assembling Eye/Pupil Camera Housing: 手順 12、 1の画像 1
    • One screw removed from the back.
  13. Dis/assembling Eye/Pupil Camera Housing: 手順 13、 1の画像 1
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  14. Dis/assembling Eye/Pupil Camera Housing: 手順 14、 1の画像 1
    • Pull off bottom stand until it breaks off.
  15. Dis/assembling Eye/Pupil Camera Housing: 手順 15、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 15、 2の画像 2
    • Remove rubber/plastic piece from the bottom
  16. Dis/assembling Eye/Pupil Camera Housing: 手順 16、 1の画像 1
    • Remove four screws from under the plastic tape (removed from last step).
  17. Dis/assembling Eye/Pupil Camera Housing: 手順 17、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 17、 2の画像 2
    • Bottom pops off
  18. Dis/assembling Eye/Pupil Camera Housing: 手順 18、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 18、 2の画像 2
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  19. Dis/assembling Eye/Pupil Camera Housing: 手順 19、 1の画像 1
    • Take out PCB from the plastic housing.
  20. Dis/assembling Eye/Pupil Camera Housing: 手順 20、 3の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 20、 3の画像 2 Dis/assembling Eye/Pupil Camera Housing: 手順 20、 3の画像 3
    • Remove the rest of the black plastic housing.
  21. Dis/assembling Eye/Pupil Camera Housing: 手順 21、 1の画像 1
    • Black plastic housing removed
  22. Dis/assembling Eye/Pupil Camera Housing: 手順 22、 3の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 22、 3の画像 2 Dis/assembling Eye/Pupil Camera Housing: 手順 22、 3の画像 3
    • Continue removing the black plastic housing surrounding the inner PCB.
  23. Dis/assembling Eye/Pupil Camera Housing: 手順 23、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 23、 2の画像 2
    • PCB removed from the black plastic housing.
  24. Dis/assembling Eye/Pupil Camera Housing: 手順 24、 1の画像 1
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  25. Dis/assembling Eye/Pupil Camera Housing: 手順 25、 1の画像 1
    • Unscrew the lens
  26. Dis/assembling Eye/Pupil Camera Housing: 手順 26、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 26、 2の画像 2
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  27. Dis/assembling Eye/Pupil Camera Housing: 手順 27、 3の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 27、 3の画像 2 Dis/assembling Eye/Pupil Camera Housing: 手順 27、 3の画像 3
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  28. Dis/assembling Eye/Pupil Camera Housing: 手順 28、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 28、 2の画像 2
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  29. Dis/assembling Eye/Pupil Camera Housing: 手順 29、 1の画像 1
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  30. Dis/assembling Eye/Pupil Camera Housing: 手順 30、 3の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 30、 3の画像 2 Dis/assembling Eye/Pupil Camera Housing: 手順 30、 3の画像 3
    • Insert PCB into 3d-printed frame.
  31. Dis/assembling Eye/Pupil Camera Housing: 手順 31、 2の画像 1 Dis/assembling Eye/Pupil Camera Housing: 手順 31、 2の画像 2
    • Completed assembly.
    • Sugru used for nose/head rest
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Silas
メンバー登録日: 11/25/13
318 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 650
