はじめに
It can be extremely dangerous to ride a dirt bike while the tire spoke is broken. This guide provides the necessary steps to fix the tire without any professional assistance, and will be cost effective while offering a fresh set of skills and knowledge to the fixer. This process can be easily achieved with the right tools, like the ones suggested below, and following each step correctly.
必要な工具と部品
Remove the valve stem cap, then let the air out of the tube by pushing in on the valve end with either a fingernail or the open end of your smaller wrench.
Use a 12 mm wrench to loosen the rim lock nut as far as possible without removing it.
Push down on the edges of the tire to break the bead and create a gap between the rim and tire. Work around the entire tire until the tire is loose from the rim.
Flip the tire over, then repeat the process of breaking the bead.
Leave the spoon nearest the rim lock in position to prevent the tire from slipping back over the rim.
Use one spoon and, inserting it every 6-8 inches, work around the tire levering it over the edge of the rim.
Once the tire is completely over the rim, flip the tire over and repeat Steps 5 and 6 to bring the tire over the rim on both sides.
Flip the tire over, and insert a spoon on either side of the rim lock.
Pull on the rim lock nut so it goes in towards the center as far as possible.
Use the spoons to lever the tire out and over the rim lock, then push the rim lock nut the other way so the tire drops between the rim lock and the rim.
If upon filling the tire it won't hold air, most likely the spoons pinched the tube and caused a hole while reinstalling the tire. If this is the case, it will be necessary to remove the tire again and patch or replace the tube before installing the tire again. Otherwise, enjoy riding!
3 の人々がこのガイドを完成させました。
