メインコンテンツにスキップ
Direct-Drive Turntable Cartridge and Needle Replacement
必要な工具と部品
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: 手順 1、 1の画像 1
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 2、 3の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 2、 3の画像 2 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 2、 3の画像 3
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 3、 3の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 3、 3の画像 2 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    購入する
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 4、 2の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 4、 2の画像 2
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 5、 2の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 5、 2の画像 2
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 6、 3の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 6、 3の画像 2 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 6、 3の画像 3
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 7、 3の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 7、 3の画像 2 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 7、 3の画像 3
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 8、 3の画像 1 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 8、 3の画像 2 Direct-Drive Turntable Cartridge and Needle Replacement: 手順 8、 3の画像 3
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: 手順 9、 1の画像 1
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
ゴール
作成者
2人の作成者と共同で作成されました。
Dylan Udhesister
メンバー登録日: 09/18/20
169 ポイント
1ガイドが承認済み
チーム
York University, Team S3-G64, Melo-Thaiss Fall 2020 York University, Team S3-G64, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S3G64
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 37
今までの合計 884
