はじめに
This guide will teach you how to remove your front/rear facing camera so that you can replace them. This is for if your cameras are not functioning properly or not working at all. You should feel comfortable taking apart your device and using a plastic opening tool to do so. You will also need to be able to identify components of your device and you can learn to do that by following this guide here ケーブルコネクタの識別と接続の外し方.
必要な工具と部品
Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
