メインコンテンツにスキップ
Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement
必要な工具と部品
  1. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, External Cover: 手順 1、 1の画像 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 2、 2の画像 1 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 2、 2の画像 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 3、 2の画像 1 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 3、 2の画像 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement, Front/Rear Facing Camera: 手順 4、 1の画像 1
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  5. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 5、 2の画像 1 Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  6. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 6、 1の画像 1
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  7. Digital2 Platinum Pad 9 Rear/Front Facing Camera Replacement: 手順 7、 1の画像 1
    • Finally remove the cameras.
終わりに
作成者
2人の作成者と共同で作成されました。
David DeMeritt
メンバー登録日: 03/08/16
637 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 98
