メインコンテンツにスキップ
Digital2 Platinum Pad 9 Motherboard Replacement
必要な工具と部品
  1. Digital2 Platinum Pad 9 Motherboard Replacement, External Cover: 手順 1、 1の画像 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 2、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 2、 2の画像 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 3、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 3、 2の画像 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Motherboard Replacement, External Speaker: 手順 4、 1の画像 1
    • The external speakers are located in the black plastic fixture near the battery as pointed to in the image.
  5. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 5、 1の画像 1
    • Use a J0 sized Phillips head screwdriver to remove the two 3.175mm long Phillips head screws from the speaker fixture.
  6. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 6、 1の画像 1
    • Then lift up the cover holding the speakers down.
    • Remove the actual speakers along with the cover.
  7. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the tape holding the wires down.
  8. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 8、 1の画像 1
    • The two wires that connect the speakers to the motherboard must be removed next. In order to replace the speakers you will need to solder them back into place.
  9. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 9、 1の画像 1
  10. Digital2 Platinum Pad 9 Motherboard Replacement, Battery: 手順 10、 1の画像 1
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  11. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 11、 1の画像 1
    • Carefully remove the tape that is holding down the battery.
  12. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 12、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 12、 2の画像 2
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  13. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 13、 1の画像 1
  14. Digital2 Platinum Pad 9 Motherboard Replacement, Volume Buttons: 手順 14、 1の画像 1
    • You can locate the volume buttons on one of the longer sides of the tablet.
  15. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 15、 1の画像 1
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  16. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 16、 1の画像 1
    • Then remove the ribbon cable from the ZIF connector.
  17. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 17、 1の画像 1
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  18. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 18、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 18、 2の画像 2
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
  19. Digital2 Platinum Pad 9 Motherboard Replacement, Front/Rear Facing Camera: 手順 19、 1の画像 1
    • The front/rear facing cameras are located in the corner of the device one is facing toward you and is black. The other is facing away so you will see the white backing.
  20. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 20、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 20、 2の画像 2
    • Use the plastic opening tool to pop up the cameras from their slot in the Tablet.
    • Then use your hand to lift up the cameras.
    • Make sure not to tear the ribbon cables.
  21. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 21、 1の画像 1
    • Use a smaller plastic opening tool to lift up the ZIF connector in which the cameras are plugged into.
  22. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 22、 1の画像 1
    • Finally remove the cameras.
  23. Digital2 Platinum Pad 9 Motherboard Replacement, Motherboard: 手順 23、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement, Motherboard: 手順 23、 2の画像 2
    • Use a J0 sized Phillips head screwdriver to remove the three 3.175mm long Phillips head screws from the motherboard.
  24. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 24、 2の画像 1 Digital2 Platinum Pad 9 Motherboard Replacement: 手順 24、 2の画像 2
    • Insert the plastic opening tool to pop up the ZIF connector holding the ribbon cable down.
    • Remove the ribbon cable.
  25. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 25、 1の画像 1
    • Remove the ribbon cable from the ZIF connector, it is next to the volume buttons.
  26. Digital2 Platinum Pad 9 Motherboard Replacement: 手順 26、 1の画像 1
    • Desolder the connections that are soldered to the motherboard. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
    • Then remove the motherboard by lifting it away.
終わりに
作成者
1人の作成者と共同作成されました。
David DeMeritt
メンバー登録日: 03/08/16
637 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 223
