メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
We will be replacing the speaker in the tablet by first taking the tablet apart. Luckily it can be easily removed with wire cutters or a soldering iron.
パーツ
パーツは指定されていません。
  1. Remove the two Phillips #00 screws from the bottom of the case.
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Wedge the opening tool in the space between the back and the front of the tablet. Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
終わりに
ある他の人がこのガイドを完成しました。
Lindsay Richardson
メンバー登録日: 2015年09月16日
394 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 94
