メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Digital2 D2-912 Screen Replacement
必要な工具と部品
  1. Digital2 D2-912 Screen Replacement, External Cover: 手順 1、 1の画像 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Screen Replacement: 手順 2、 2の画像 1 Digital2 D2-912 Screen Replacement: 手順 2、 2の画像 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Screen Replacement, Screen: 手順 3、 1の画像 1
    • Be sure to remove the yellow tape that is holding the components down.
    • Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
    • When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
  4. Digital2 D2-912 Screen Replacement: 手順 4、 1の画像 1
    • Using the metal spudger, pry the display from the screen.
  5. Digital2 D2-912 Screen Replacement: 手順 5、 1の画像 1
    • The screen is now ready to be replaced by the new one
終わりに
作成者
3人の作成者と共同で作成されました。
Lindsay Richardson
メンバー登録日: 09/16/15
394 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S1G1
4 メンバー
6のガイドは作成済み
3 件のコメント
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Dr. Wolfgang Mohr - 返信
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
Super Manny - 返信
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
Rocia Patrick - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 619
