メインコンテンツにスキップ
Digital2 D2-912 Screen Replacement
必要な工具と部品
  1. Digital2 D2-912 Screen Replacement, External Cover: 手順 1、 1の画像 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Screen Replacement: 手順 2、 2の画像 1 Digital2 D2-912 Screen Replacement: 手順 2、 2の画像 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Screen Replacement, Screen: 手順 3、 1の画像 1
    • Be sure to remove the yellow tape that is holding the components down.
    • Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
    • When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
    More detail about how to remove the yellow tab.
    Natalie Holm - 返信
  4. Digital2 D2-912 Screen Replacement: 手順 4、 1の画像 1
    • Using the metal spudger, pry the display from the screen.
  5. Digital2 D2-912 Screen Replacement: 手順 5、 1の画像 1
    • The screen is now ready to be replaced by the new one
終わりに
作成者
3人の作成者と共同で作成されました。
Lindsay Richardson
メンバー登録日: 09/16/15
394 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S1G1
4 メンバー
6のガイドは作成済み
3 件のコメント
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Dr. Wolfgang Mohr - 返信
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
Super Manny - 返信
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
Rocia Patrick - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 617
