この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will be showing you how to replace the LCD screen. Be sure to carefully remove components to avoid damaging the device.
必要な工具と部品
Remove the two 3.51mm screws that are located on the top corners of the device with the same phillips screwdriver..
Next, unplug the ZIF connector and slide it out with the pointed side of the spudger.
To unclip the connector, go under the black tap and simply lift with your finger nail or spudger.
もう少しです!
終わりに
