メインコンテンツにスキップ
Digital2 D2-861G LCD Screen Replacement
必要な工具と部品
  1. Digital2 D2-861G LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards
  2. Digital2 D2-861G LCD Screen Replacement: 手順 2、 2の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 2、 2の画像 2
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G LCD Screen Replacement: 手順 3、 3の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 3、 3の画像 2 Digital2 D2-861G LCD Screen Replacement: 手順 3、 3の画像 3
    • Look at the images to locate the black tabs.
    • Carefully remove the tape to avoid damaging the device.
    • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
    • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
  4. Digital2 D2-861G LCD Screen Replacement: 手順 4、 2の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 4、 2の画像 2
    • Make sure to not bend or puncture the battery when removing it.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Use prying tools to carefully break the adhesive under the battery
  5. Digital2 D2-861G LCD Screen Replacement, LCD Screen: 手順 5、 2の画像 1 Digital2 D2-861G LCD Screen Replacement, LCD Screen: 手順 5、 2の画像 2
    • Locate the flat-top connector. Go under it with the spudger and simply lift up.
  6. Digital2 D2-861G LCD Screen Replacement: 手順 6、 2の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 6、 2の画像 2
    • To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
  7. Digital2 D2-861G LCD Screen Replacement: 手順 7、 2の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 7、 2の画像 2
    • Be sure to have a magnetic mat or anything magnetic to hold your screws!
    • Remove two 3.51mm screws located on the bottom corners of the device with your Phillips #00 Screwdriver.
    • Carefully lift the casing and pull back the tape along with the soldered wire.
    • You can remove the soldered wire if you want or leave it connected. Refer to iFixit's guide on how to Solder はんだ付けとはんだ除去の作業ガイド
  8. Digital2 D2-861G LCD Screen Replacement: 手順 8、 3の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 8、 3の画像 2 Digital2 D2-861G LCD Screen Replacement: 手順 8、 3の画像 3
    • Make sure to have your magnetic board to hold your screws!
    • Remove the two 3.51mm screws that are located on the top corners of the device with the same phillips screwdriver..
    • Next, unplug the ZIF connector and slide it out with the pointed side of the spudger.
    • To unclip the connector, go under the black tap and simply lift with your finger nail or spudger.
  9. Digital2 D2-861G LCD Screen Replacement: 手順 9、 1の画像 1
    • Use little force or else you risk breaking the motherboard.
    • Watch out for the ZIF connector!
    • To remove the motherboard, grab the component on the top left and gently lift. Be careful with the clip holding the motherboard.
  10. Digital2 D2-861G LCD Screen Replacement: 手順 10、 3の画像 1 Digital2 D2-861G LCD Screen Replacement: 手順 10、 3の画像 2 Digital2 D2-861G LCD Screen Replacement: 手順 10、 3の画像 3
    • Now that every component is removed, use the flat side of the spudger and insert it on the bottom of the screen.
    • Gently move along the edges to lift the screen.
  11. Digital2 D2-861G LCD Screen Replacement: 手順 11、 1の画像 1
    • If you have a damaged front case, take the opportunity to replace that as well.
終わりに
作成者
2人の作成者と共同で作成されました。
Eduardo Duran
メンバー登録日: 09/29/16
600 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Crane Fall 2016 Eastern Washington University, Team 1-3, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 452
