Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
Place your device on a soft cloth to avoid scratching the screen
Flip your device over so back panel is facing upwards.
Do not use a lot of force as it can break the clips or the back panel.
Insert spudger in the slot below the micro SD card.
You should hear clips releasing as you pry along the edges.
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Avoid pulling the gold connector as it can be damaged and/or broken.
To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
