Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
Place your device on a soft cloth to avoid scratching the screen.
Flip your device over so back panel is facing upwards
Do not use a lot of force as it can break the clips or the back panel.
Insert spudger in the slot below the micro SD card
You should hear clips releasing as you pry along the edges.
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Look at the images to locate the black tabs.
Carefully remove the tape to avoid damaging the device.
Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
Make sure to not bend or puncture the battery when removing it.
Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
Use prying tools to carefully break the adhesive under the battery
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
