メインコンテンツにスキップ
はじめに
This guide will be showing you how to replace the 3.7V battery in the back of the tablet. Be sure to carefully remove the battery from the back of the screen and do not puncture it.
Battery information:
- JZ Li-ion PL28106110
+ 3.7V 3100MAH 1406
パーツ
パーツは指定されていません。
  1. Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards
  2. Do not use a lot of force as it can break the clips or the back panel. Insert spudger in the slot below the micro SD card
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Look at the images to locate the black tabs. Carefully remove the tape to avoid damaging the device. Remove ALL the yellow tape securing the  gold colored ZIF (Zero insertion force) connector and the battery. Discard  or save the tape if you would like.
    • Look at the images to locate the black tabs.
    • Carefully remove the tape to avoid damaging the device.
    • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
    • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
  4. Make sure to not bend or puncture the battery when removing it. Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Make sure to not bend or puncture the battery when removing it.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Use prying tools to carefully break the adhesive under the battery
終わりに
Dalton Berg
メンバー登録日: 2016年09月29日
201 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-3, Crane Fall 2016 Eastern Washington University, Team 1-3, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G3
3 メンバー
6のガイドは作成済み
コメント1件
where do you find the replacement battery?
rsdii - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 790
