メインコンテンツにスキップ
Digital2 7" Tablet D2-713G GN Speaker Replacement
必要な工具と部品
  1. Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 手順 1、 3の画像 1 Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 手順 1、 3の画像 2 Digital2 7" Tablet D2-713G GN Speaker Replacement, Opening the device to expose components: 手順 1、 3の画像 3
    • With the appropriate tools on hand, you want to look for the charging port.
    • Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border.
    • Now continue to pry the case with the same technique all around.
    • After prying all around the device, you will be able to separate the back cover from the display , which holds all the components.
  2. Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 手順 2、 3の画像 1 Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 手順 2、 3の画像 2 Digital2 7" Tablet D2-713G GN Speaker Replacement, Locating and replacing the speaker: 手順 2、 3の画像 3
    • Once you have opened the case completely, you will be able to see the speaker.
    • With one hand hold the device down to the table and with the other hand remove the speaker from where it sits.
    • Follow the black and red wires to the circuit board.
    • The wires will have to be removed with a soldering tool.
    • This process is also needed when installing the new speaker.
終わりに
作成者
1人の作成者と共同作成されました。
Miguel A Rodriguez
メンバー登録日: 10/25/14
590 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-6, Johnson Fall 2014 Gateway, Team 1-6, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G6
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 256
