はじめに
Use this guide to replace the camera assembly, which includes the front and rear facing cameras.
パーツ
パーツは必要ありません。
  1. With the appropriate tools on hand, you want to look for the charging port. Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border. Now continue to pry the case with the same technique all around.
    • With the appropriate tools on hand, you want to look for the charging port.
    • Once you have located your charging port, to the right of it you will be able to insert the prying tool into the crack between the case and the display border.
    • Now continue to pry the case with the same technique all around.
    • After prying all around the device, you will be able to separate the back cover from the display , which holds all the components.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Once you have opened the case completely, you will be able to see the front and back facing cameras. With your tweezers, carefully lift the cameras out of their place. the cameras are held together by a ribbon cable. Be careful not to damage the ribbon when pulling the cameras out. Now that the speakers are out of their place, you will need to disconnect the ribbon connector from the circuit board.
    • Once you have opened the case completely, you will be able to see the front and back facing cameras.
    • With your tweezers, carefully lift the cameras out of their place. the cameras are held together by a ribbon cable. Be careful not to damage the ribbon when pulling the cameras out.
    • Now that the speakers are out of their place, you will need to disconnect the ribbon connector from the circuit board.
    • When all of the previous steps have been completed, you will be able to install the new cameras into your device.
まとめ
Miguel A Rodriguez
メンバー登録日: 2014年10月25日
592 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-6, Johnson Fall 2014 Gateway, Team 1-6, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G6
2 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 174
