必要な工具と部品
The reading changes all the time, there is some dust or dirt in the sensor.
The problem is actually, how do you open it...
There is a very thick and well glued label on the back which hides the screws which need to be removed. Then it is easy.
When everything is disassembled, generally a cleaning of the surfaces is enough to make it work again.
Do not forget to readjust the screws tightening the sliding joint. Is is on the side.
ある他の人がこのガイドを完成しました。
