メインコンテンツにスキップ
Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement
必要な工具と部品
  1. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: 手順 1、 3の画像 1 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: 手順 1、 3の画像 2 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: 手順 1、 3の画像 3
    • Locate the four 3.5 mm Phillips screws holding the silver back plate and the screen together. There are two screws on the top and two screws on the bottom.
    • Using the Phillips #00 Screwdriver, remove all four screws.
    • ● Remove the screws with the least amount of force possible to avoid damage to the threads. If thread damage occurs, screw removal will become more difficult.
  2. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: 手順 2、 3の画像 1 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: 手順 2、 3の画像 2 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: 手順 2、 3の画像 3
    • Flip your device so that the long side without the buttons faces you.
    • Insert the Plastic Opening Tool between the silver back plate and the screen about one inch from the corner of the device on either side.
    • Using the Plastic Opening Tool, pry open the screen until it unsnaps from the back plate.
    • Work your way down the edge of the device, unsnapping all locations where the screen meets the silver back plate.
    • Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
    • Once the screen is loose, pull it towards you, then lift it to prevent damage to the buttons on the other side of the device.
  3. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: 手順 3、 3の画像 1 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: 手順 3、 3の画像 2 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: 手順 3、 3の画像 3
    • Using a pair of tweezers, poke the square plastic piece between each of the buttons that connect them together. Each button has a plastic piece between their gaps.
    • While poking the square piece in, simultaneously push it upward to release it.
    • After releasing the first one, use the pair of tweezers, and do the same with the second one. This should free all buttons from the device.
    • Once the buttons are free, use the set of tweezers to grab the buttons and pull them out.
終わりに
作成者
6人の作成者と共同で作成されました。
Seth York
メンバー登録日: 01/20/15
355 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 11-6, Blackwell Winter 2015 USF Tampa, Team 11-6, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S11G6
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 241
