メインコンテンツにスキップ
Digiland 10.1'' DL1016 Screen Replacement
必要な工具と部品
  1. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: 手順 1、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: 手順 1、 2の画像 2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Screen Replacement: 手順 2、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement: 手順 2、 2の画像 2
    • Gently lift the backing off.
  3. 注意: 手順 3 は、作業進行中としてマークされている ガイド から引用されています。
    Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 手順 3、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 手順 3、 2の画像 2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: 手順 4、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: 手順 4、 2の画像 2
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Screen Replacement, Power Button: 手順 5、 1の画像 1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Screen Replacement: 手順 6、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement: 手順 6、 2の画像 2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Screen Replacement, Screen: 手順 7、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement, Screen: 手順 7、 2の画像 2
    • Remove the tape from the backside of the tablet along with the wiring.
    • Make space so you can pry the motherboard away from the digitizer.
  8. Digiland 10.1'' DL1016 Screen Replacement: 手順 8、 2の画像 1 Digiland 10.1'' DL1016 Screen Replacement: 手順 8、 2の画像 2
    • Once the motherboard is pulled away, the screen should be free of all other components.
    • Check around the edges so that no tape is stuck to the edges or wiring and just push off digitizer and replace screen if needed.
終わりに
作成者
2人の作成者と共同で作成されました。
Virginia Tapia
メンバー登録日: 08/26/19
395 ポイント
3のガイドは作成済み
チーム
Gateway, Team S1-G2, Saknee Fall 2019 Gateway, Team S1-G2, Saknee Fall 2019人のメンバー
GCC-SAKNEE-F19S1G2
4 メンバー
5のガイドは作成済み
3件のガイドコメント
Where can i get the screen for this tablet? i need to order online and currently i am in india.
Arivu Alagan - 返信
Where will I get screen in kenya
Josphat Mutai - 返信
My phone crack,I need screen only
Josphat Mutai - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 2,056
