メインコンテンツにスキップ
はじめに
If the DC power connector is broken this guide will teach you how to remove the broken component for replacement.
パーツ
パーツは指定されていません。
  1. Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks. Remove the four 8mm Phillips #0 screws located on the back panel.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. Remove the back panel to expose the motherboard. Remove the back panel to expose the motherboard.
    • Remove the back panel to expose the motherboard.
  3. Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. Desolder the back of the motherboard where the power connector is located.
    • Desolder the back of the motherboard where the power connector is located.
終わりに
Elijah Smith
メンバー登録日: 2018年09月10日
726 ポイント
6のガイドは作成済み
チーム
Appalachian State University, Team S2-G2, Menagarishvili Fall 2018 Appalachian State University, Team S2-G2, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 221
