メインコンテンツにスキップ
はじめに
If the amp/mixer switch is broken this guide will teach you how to remove the broken component for replacement.
パーツ
パーツは指定されていません。
  1. Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks. Remove the four 8mm Phillips #0 screws located on the back panel.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. Remove the back panel to expose the motherboard. Remove the back panel to expose the motherboard.
    • Remove the back panel to expose the motherboard.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  5. Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  6. Desolder the back of the motherboard where you want to replace the switch.
    • Desolder the back of the motherboard where you want to replace the switch.
まとめ
Elijah Smith
メンバー登録日: 2018年09月10日
696 ポイント
6のガイドは作成済み
チーム
Appalachian State University, Team S2-G2, Menagarishvili Fall 2018 Appalachian State University, Team S2-G2, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G2
3 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 74
