この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Be careful as you follow, and complete the steps listed in this guide. If a component is not coming out smoothly, make sure that all screws that need to be removed were removed. As you're removing the Screen or operating near it, watch out for any flex cable to avoid damaging them.
必要な工具と部品
Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
Once the back panel has been removed, it is best to set it aside in a safe location.
By using the J000 screwdriver, remove the 10 screws from the back. When the tablet is oriented like the picture, there are 6 screws to the left and 4 screws to the right. Set aside the screws in a safe place for re-installation.
6 の人々がこのガイドを完成させました。
3 件のコメント
I can't find a replacement lcd screen mine has the rainbow colored liquid marks on the lcd and there's lines going across the screen i have the digiland model# DL801W 8" Windows 10 tablet
Yes Amazon supposedly has them for $19. I need one myself as it is cracked. The protection & cover not protect it.
Where can i find a replacement lcd display screen for digiland DL801W i do not need the digitizer i just need the inner lcd screen
