メインコンテンツにスキップ
DigiLand DL801W Power and Volume Button Assembly Replacement
必要な工具と部品
  1. DigiLand DL801W Power and Volume Button Assembly Replacement, Power and Volume Button Assembly: 手順 1、 1の画像 1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 2、 1の画像 1
    • Remove the 10 JIS #000 screws from the back of the device.
  3. DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 3、 3の画像 1 DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 3、 3の画像 2 DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 3、 3の画像 3
    • Using a spudger, lift the flaps securing the four ZIF connectors.
    • The smaller of the four flaps may require you to use the point end of the spudger.
    • Use the pointed end of the spudger to disconnect the ribbon cables from their ZIF connectors.
    • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
  4. DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 4、 1の画像 1
    • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
  5. DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 5、 2の画像 1 DigiLand DL801W Power and Volume Button Assembly Replacement: 手順 5、 2の画像 2
    • Disconnect battery terminal using the black spudger.
    • Once the battery is disconnected, the motherboard should lift right off of the metal back plate.
    • Now you will be able to remove the Power Button and Volume Assembly with a soldering iron.
終わりに
作成者
2人の作成者と共同で作成されました。
Travis Mangum
メンバー登録日: 09/17/15
572 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,593
