メインコンテンツにスキップ
DigiLand DL801W Microphone Replacement
必要な工具と部品
  1. DigiLand DL801W Microphone Replacement, Microphone: 手順 1、 1の画像 1
    • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Microphone Replacement: 手順 2、 1の画像 1
    • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
    • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Travis Mangum
メンバー登録日: 09/17/15
572 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 332
