メインコンテンツにスキップ
DigiLand DL701Q Back Case Replacement
必要な工具と部品
  1. DigiLand DL701Q Back Case Replacement, Back Case: 手順 1、 3の画像 1 DigiLand DL701Q Back Case Replacement, Back Case: 手順 1、 3の画像 2 DigiLand DL701Q Back Case Replacement, Back Case: 手順 1、 3の画像 3
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: 手順 2、 3の画像 1 DigiLand DL701Q Back Case Replacement: 手順 2、 3の画像 2 DigiLand DL701Q Back Case Replacement: 手順 2、 3の画像 3
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jonathan Mysona
メンバー登録日: 03/21/16
1,135 ポイント
7のガイドは作成済み
チーム
Clemson, Team 6-1, Benson Spring 2016 Clemson, Team 6-1, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S6G1
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 905
