メインコンテンツにスキップ
Diagnosing and Erasing Hard Drives
必要な工具と部品
  1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 手順 1、 3の画像 1 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 手順 1、 3の画像 2 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: 手順 1、 3の画像 3
    • If the drive is not installed in a PC, a USB adapter can be used. If you are using an M.2 SSD (NVMe or SATA) you will need a different enclosure than shown in these guide photos.
    • If the hard drive is not installed and you do not have a USB adapter, it can be plugged into a motherboard.
  2. Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 手順 2、 3の画像 1 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 手順 2、 3の画像 2 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: 手順 2、 3の画像 3
    • While high hours are not an indication of failure, the odds of a failure are much higher.
    • GSmartControl can be used in Ubuntu if you cannot read the output from Disks.
    • Boot your system into a live Ubuntu session. Locate the Disks application and select the suspicious hard drive.
    • From the drop-down menu, select SMART Data and Self Tests. This will pull up the SMART data.
    • Locate the following SMART attributes: Power On Hours and Power Cycle Count.
  3. Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 手順 3、 3の画像 1 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 手順 3、 3の画像 2 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: 手順 3、 3の画像 3
    • If the Reallocated Sector Count is highlighted with a high count, REPLACE THE DRIVE; they are prone to failure and unexpected capacity loss! While SMART Extended is better, a quick test may be sufficient.
    • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
    • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
  4. Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 手順 4、 3の画像 1 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 手順 4、 3の画像 2 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: 手順 4、 3の画像 3
    • Select Disks from the desktop to open GSmartControl.
    • Select the hard disk you want to test. Click Attributes to read the SMART data.
    • Locate the following attributes: Power On Time and Power Cycle Count.
  5. Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 手順 5、 3の画像 1 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 手順 5、 3の画像 2 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: 手順 5、 3の画像 3
    • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
    • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
  6. Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 手順 6、 3の画像 1 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 手順 6、 3の画像 2 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: 手順 6、 3の画像 3
    • Use the error log and SMART data together to diagnose drive problems.
    • Check the error log for drive errors. Click the Error log tab, and review the logs.
    • In the Error log, review the available errors. Read these logs if any are found.
  7. Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 手順 7、 3の画像 1 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 手順 7、 3の画像 2 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: 手順 7、 3の画像 3
    • When possible, avoid sector-wiping SSDs. This will reduce the drive liftetime and can be drastic on older 75TBW SSDs.
    • Your erase options will be limited to the Security Set options supported in the drive firmware.
    • Drives without ATA Secure Erase will need to be erased externally. Select External and choose Nwipe. Run the DoD Short command (3 wipes+drive blanking).
    • If your drive has a buggy ATA Secure Erase implementation, choose External and erase the drive with Nwipe. SSDs should only be erased with the Secure Erase command.
    • For NVMe SSDs, the best option is to use NVMe Secure Erase.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Nick
メンバー登録日: 11/10/09
89,825 ポイント
52のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,516のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 39
今までの合計 1,884
