メインコンテンツにスキップ
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
必要な工具と部品
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: 手順 1、 1の画像 1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 2、 2の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 2、 2の画像 2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 3、 3の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 3、 3の画像 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 3、 3の画像 3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 4、 2の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 4、 2の画像 2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 9、 1の画像 1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 11、 2の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 11、 2の画像 2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 13、 1の画像 1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 14、 3の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 14、 3の画像 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 14、 3の画像 3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 17、 3の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 17、 3の画像 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 17、 3の画像 3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 18、 1の画像 1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 20、 2の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 20、 2の画像 2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 21、 1の画像 1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 22、 3の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 22、 3の画像 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 22、 3の画像 3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 24、 3の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 24、 3の画像 2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 24、 3の画像 3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 25、 2の画像 1 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 25、 2の画像 2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 手順 26、 1の画像 1
    • Finally, reposition the vacuum bag.
ゴール
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
HelloMacOSさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Céline Chemineau
メンバー登録日: 01/29/20
16,581 ポイント
95のガイドは作成済み
チーム
Leroy Merlin Leroy Merlin人のメンバー
Community
36 メンバー
239のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 148
