はじめに
This guide will show you how to replace the gearcase assembly on the Dewalt DW511 Hammer Drill. The gearcase is responsible for the translation of motion between the motor and the spinning bit, controlling the speed and torque of the motion. The gearcase is attached to the armature, so the entire assembly will need to be removed as one piece.
必要な工具と部品
Firmly grab the body of the trigger.
Slowly pull the trigger until the entire body is out and only attached by wires.
Use an opening tool to lift up the spring holding down the brush.
Remove the brush from its holding.
Hold the hammer drill tool firmly by the handle.
Gently separate the gear case unit from the hammer drill body.
