メインコンテンツにスキップ
Dewalt Air Compressor DWFP55126 2016 Pump Replacement
必要な工具と部品
  1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 手順 1、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 手順 1、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 手順 1、 3の画像 3
    • Disconnect the power cord, depressurize the compressor tank, and remove any hoses before starting this repair.
    • Use a long-shank T10 driver to remove the manifold cover screw.
    • Lift the cover directly up off of the gauges to remove.
  2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: 手順 2、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: 手順 2、 2の画像 2
    • Use a T20 driver to remove the two handle screws, one on each side.
  3. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 3、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 3、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 3、 3の画像 3
    • Grab the handle like you would if you were to pick the compressor up. Pull up and push forward away from the gauges at the same time to rotate the handle up off the case.
    • Lift the handle off to remove.
  4. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 手順 4、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 手順 4、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 手順 4、 3の画像 3
    • Remove the following four screws:
    • Three 20 mm-long T20 screws.
    • One 20 mm-long Phillips #1 screw.
  5. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 5、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 5、 2の画像 2
    • Four metal tabs on the tank sit in four slots on the top plastic case to secure the case to the tank.
    • Firmly push the top case off of the four tabs to detach.
  6. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 6、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 6、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 6、 3の画像 3
    • Carefully pull the half of the case that is opposite the manifold away from the tank.
    • The motor may shift once the case is removed, but it won't fall out.
    • Reassembly tip: align the power cord in the cord cutout so it doesn't get pinched.
  7. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 手順 7、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 手順 7、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 手順 7、 3の画像 3
    • Use a large flathead screwdriver to depress the plastic tab on the red power switch closest to the open side of the case.
    • While keeping the tab depressed, grab the top side of the switch and pull directly up off the case.
    • Pull the switch farther out of the case.
    • Don't try to completely remove the switch; there are still wires attached below.
  8. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 8、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 8、 2の画像 2
    • Use a flathead screwdriver to pry both wire connectors slightly off the plugs on the bottom of the switch.
  9. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 9、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 9、 2の画像 2
    • Once the wires are loosened from the plugs on the switch, completely remove both wires.
    • Remove the power switch.
  10. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: 手順 10、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: 手順 10、 2の画像 2
    • Carefully pull to remove the connector on the ground wire located inside the case.
  11. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 手順 11、 3の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 手順 11、 3の画像 2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 手順 11、 3の画像 3
    • Use needle nose pliers to bend the check valve hose clamp up away from the hose.
    • Once the hose clamp is bent enough to clear the hose, lift it up and off to remove.
    • We strongly suggest you replace this hose clamp during reassembly to prevent leaks during operation.
  12. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 12、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 手順 12、 2の画像 2
    • Pull the hose off the fitting to remove.
  13. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: 手順 13、 2の画像 1 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: 手順 13、 2の画像 2
    • While holding the plastic housing, pull the pump assembly out, careful to not snag hoses or wires.
終わりに
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
117,484 ポイント
339のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,801のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 51
今までの合計 2,615
