メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Desktop PC RAM Replacement
必要な工具と部品
  1. Desktop PC RAM Replacement, Left Panel: 手順 1、 1の画像 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: 手順 2、 2の画像 1 Desktop PC RAM Replacement: 手順 2、 2の画像 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: 手順 3、 1の画像 1
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: 手順 4、 1の画像 1
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
終わりに
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
David Lennon
メンバー登録日: 04/14/15
10,144 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G5
4 メンバー
45のガイドは作成済み
4件のガイドコメント
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - 返信
very interesting
maciekErd123 - 返信
how to determine the speed
benzy aceware - 返信
how can i differentiate between types of rams
benzy aceware - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 37
過去 30 日: 132
今までの合計 8,285
