メインコンテンツにスキップ
Desktop PC Graphics Card Replacement
必要な工具と部品
  1. Desktop PC Graphics Card Replacement, Left Panel: 手順 1、 1の画像 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - 返信
    This is correct.
    DistroHopper39B -
  2. Desktop PC Graphics Card Replacement: 手順 2、 2の画像 1 Desktop PC Graphics Card Replacement: 手順 2、 2の画像 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Graphics Card Replacement, Graphics Card: 手順 3、 1の画像 1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Desktop PC Graphics Card Replacement: 手順 4、 2の画像 1 Desktop PC Graphics Card Replacement: 手順 4、 2の画像 2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
    Sur les ports récents, (PCIE) il y a d’abord l’encoche à éloigner pour permettre le retrait de carte graphique.
    benam - 返信
    most gpu's have screws so you MUST take them out first or the pins on the gpu and pci slot will crack.
    Dovber Levertov - 返信
終わりに
78 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
David Lennon
メンバー登録日: 04/14/15
9,944 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G5
4 メンバー
45のガイドは作成済み
3 件のコメント
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - 返信
I have a all in one pc so this is not relevant
Robert Campanelli - 返信
any diffrerences in slots?
benzy aceware - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 59
過去 30 日: 192
今までの合計 15,350
