はじめに
If you have a leaking shower head, one cause could be from the shower handle cartridge letting water through when the handle is fully closed.
This cartridge is designed to mix hot and cold water from two separate pipes and exit out of your shower head. Just like other mechanical parts, the cartridge can wear out over time and not fully close when the shower handle is in the closed/off position.
Before using this guide, figure out what make and model cartridge your shower has. Some make and models may look different on the front but are similar on the back and are installed the same way as the Delta model #RP19804 shown in the guide.
必要な工具と部品
Turn off the water supply to the house by turning the knob seen here to the off position.
To reassemble your device, follow steps 1 - 4 in reverse order.
ある他の人がこのガイドを完成しました。
