メインコンテンツにスキップ
Dell c1760nw Clean main mechanics cleaning and making it work
必要な工具と部品
  1. Dell c1760nw Clean main mechanics cleaning and making it work, Remove error 007-371: 手順 1、 1の画像 1
    • Does your Dell C1760nw ( and some other LED/laserprinter models) show you incessantly the error 007-371? Then this repair guide is made for you!
  2. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the paper tray: 手順 2、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the paper tray: 手順 2、 2の画像 2
    • Remove the front paper tray by slightly bending it carefully and angling it to release the peg from the hinge slot.
  3. Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: 手順 3、 3の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: 手順 3、 3の画像 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove front housing parts: 手順 3、 3の画像 3
    • Remove the bar at the top and the front. (It snaps out with a little effort.)
  4. Dell c1760nw Clean main mechanics cleaning and making it work, Remove TopCase: 手順 4、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove TopCase: 手順 4、 2の画像 2
    • Remove two srews from the front. And to take off the cover leverage remove the tabs diagonally from the front over the latching.
  5. Dell c1760nw Clean main mechanics cleaning and making it work, Continued: Remove TopCase: 手順 5、 1の画像 1
    • Carefully lift the cover (Attention: cable connection to the display is hanging there) and rack it to the back of the printer (move it back and forth to unhook the locking nipple): unplug the display connector (yellow lines) from the I/O board, unroute the cable and remove the cover.
  6. Dell c1760nw Clean main mechanics cleaning and making it work, Remove left housing part: 手順 6、 1の画像 1
    • Place the printer on the right side and remove the left side panel (there are 2 lugs under the printer)
  7. Dell c1760nw Clean main mechanics cleaning and making it work, Next: Remove the left housing part: 手順 7、 1の画像 1
    • Reposition the printer and hold the disengaged lugs in the disengaged position. Open the rear flap and slide the side panel backwards while moving away from the printer.
  8. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the WLAN card: 手順 8、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the WLAN card: 手順 8、 2の画像 2
    • The WLAN card is secured with a screw-> remove it, carefully unplug the WLAN card and remove the WLAN bracket together with the cable
  9. Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: 手順 9、 3の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: 手順 9、 3の画像 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove I / O card: 手順 9、 3の画像 3
    • Loosen all connectors (pull plugs carefully out of sockets)
    • Pull both flexible cables out of sockets. Caution: the wider flexible cable has a base with lock. Lift it carefully with a fingernail, this releases the flexible cable and allows it to be easily pulled out of the socket.
    • I/O card is secured with 4 screws, loosen all 4.
    • There is another screw on the USB port: Loosen it
  10. Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): 手順 10、 3の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): 手順 10、 3の画像 2 Dell c1760nw Clean main mechanics cleaning and making it work, Remove metal plate (beneath I / O card): 手順 10、 3の画像 3
    • The metal plate under the I/O card (which holds the I/O card) is secured with 3 screws. Remove all 3 screws
  11. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the fan: 手順 11、 1の画像 1
    • The fan is secured to this plate with a screw (red arrow): Loosen the screw and unlock the locking device on the other side of the fan.
    • Remove the fan, disconnect the cables and plugs on the upper control board (no photo).
  12. Dell c1760nw Clean main mechanics cleaning and making it work, Unroute wiring harnesses: 手順 12、 1の画像 1
    • Unroute all cable harnesses on the left side from the guides.
    • Remove the cable guide bracket and hang it from the remaining cable harnesses on the printer.
  13. Dell c1760nw Clean main mechanics cleaning and making it work, Remove other components: 手順 13、 1の画像 1
    • A) Remove plastic bracket with gear for paper feed (2 screws) - No photo!
    • B) Remove main drive
    • C) Remove board with color control (4 screws)
  14. Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: 手順 14、 3の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: 手順 14、 3の画像 2 Dell c1760nw Clean main mechanics cleaning and making it work, B) Remove main drive: 手順 14、 3の画像 3
    • Loosen 4 screws
    • Pull the main gearbox carefully and straight off the printer. (Caution: loose gears!)
    • Last photo: This is what the dismantled main gearbox looks like: The completely muddy (color & grease) drive gear is the black (below)
  15. Dell c1760nw Clean main mechanics cleaning and making it work, C) Remove board with color control: 手順 15、 1の画像 1
    • Carefully pull the upper flexible cable out of the base
    • on the right side: 4 flexible cables with base lock. With fingernail: Open the lock, then carefully lift the flexible cable by the blue tab and remove it from the base. (hand)
  16. Dell c1760nw Clean main mechanics cleaning and making it work, Remove the color control gear: 手順 16、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Remove the color control gear: 手順 16、 2の画像 2
    • Next, we remove the color control gear (black, large plastic bracket with 15 meshing gears (5 screws have to be loosened).
    • CAUTION when removing the bracket so that the gears do not fall out!
    • 2nd photo: removed condition and THE central problem: The paint particles have combined to form a sticky mass with the gear grease.
  17. Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: 手順 17、 3の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: 手順 17、 3の画像 2 Dell c1760nw Clean main mechanics cleaning and making it work, Washing the gearwheels ...: 手順 17、 3の画像 3
    • Washing the gearwheels.
    • A toothbrush with plenty of hand soap brings good success here!
    • Attention: Every gear wheel has its position! Do not mix them up!
    • Attention: Dry all parts (brackets, gears) very well! "Knocking" the ingredients on paper towels helps!
  18. Dell c1760nw Clean main mechanics cleaning and making it work, First success: 手順 18、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, First success: 手順 18、 2の画像 2
    • The "before / after" evidence ;-)
    • I used low-viscosity grease to grease the axles and the teeth. Finally, add a splash of Balistol to the grease on the axles.
  19. Dell c1760nw Clean main mechanics cleaning and making it work, Second success: 手順 19、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Second success: 手順 19、 2の画像 2
    • And once again: before and after
  20. Dell c1760nw Clean main mechanics cleaning and making it work, Clean the chassis: 手順 20、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, Clean the chassis: 手順 20、 2の画像 2
    • Now the chassis should be cleaned (only for the good feeling! and because of the care...)
    • Moist all-purpose wipes" in a resealable plastic cover are ideal for cleaning.
  21. Dell c1760nw Clean main mechanics cleaning and making it work, After assembly: 手順 21、 2の画像 1 Dell c1760nw Clean main mechanics cleaning and making it work, After assembly: 手順 21、 2の画像 2
    • The assembly is done in reverse order... Until the printer only needs the right and front housing part plus the paper flap.
    • If the error message 007-371 appears again at the first attempt of the printout, this is nothing unusual. The paint mixing drive usually still needs a "boost".
    • Turn the printer off and on again a short time later. Now you help the gear a little bit on the jumps: for this you put on a screwdriver as shown in picture 1, hold it with a little pressure so that you can get the gear wheel touched with it a little in motion when it is released by the small relay.
    • This usually does not happen by itself during the first printing process (although the spring in the gearbox, which you probably noticed earlier, should actually trigger this momentum). So, put on the screwdriver like this and send a print job.
    • In picture 2 you can see a better close-up to attach the screwdriver exactly.
    • If everything works, then reassemble everything else and: DONE!
終わりに
Congratulations, you did it!
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
GeorgG
メンバー登録日: 01/14/11
1,000 ポイント
1ガイドが承認済み
3 件のコメント
could really use a service manual for the c1760nw if anyone has one. email is johnnysemail62@yahoo.com. Thanks in advance!
johnny - 返信
do u have manual now?
dr.wot -
it looks so easy LOL but then when you know what your doing it helps!
Thanks all the same.
BC
Ben Cowell - 返信
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 85
過去 30 日: 266
今までの合計 17,785
