メインコンテンツにスキップ
Dell XPS M1710 RAM Replacement
必要な工具と部品
  1. Dell XPS M1710 RAM Replacement, Disconnect the AC Adapter: 手順 1、 1の画像 1
    • Nobody wants to get shocked while working on their electronics! Be safe and unplug the power.
  2. Dell XPS M1710 RAM Replacement, Remove the Battery: 手順 2、 1の画像 1
    • You'll want to flip the laptop upside down, and you'll see the battery in the lower left corner (it has 5 lights on it with a battery icon, it's hard to miss).
    • To release the battery, pull the switch as far to the right as you can, and then use your fingers under the plastic grip to lift up the battery towards you.
  3. Dell XPS M1710 RAM Replacement, Remove the Memory Cover: 手順 3、 1の画像 1
    • There are two Phillips screws that hold the cover on. As you loosen them, the cover will start to pop up on the left side.
    • Once the screws are loosened, use your fingers to gently pry under the plastic right where the white "M" is and the cover will pop right off.
  4. Dell XPS M1710 RAM Replacement, Removing the RAM: 手順 4、 1の画像 1
    • You're almost there! Now it's just time to remove the RAM itself.
    • For each RAM stick, there are 2 retention clips that hold the RAM in. To release them, use your hands to pull each of the clips away from the RAM card, and the card will pop up, which then you can pull out of the slot.
    • To reinstall the RAM, be sure to insert the module at an angle similar to when the cards popped up, with the contacts inside the slot, then gently push them straight down until the retention clips pop back into place.
終わりに
To reassemble your device, follow these instructions in reverse order. See the note on Step 4 for help reinstalling the memory modules themselves.
作成者
3人の作成者と共同で作成されました。
Robert Thorpe
メンバー登録日: 12/19/15
210 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 643
