メインコンテンツにスキップ
Dell XPS 9720 SSD Replacement
必要な工具と部品
  1. Dell XPS 9720 SSD Replacement, Remove back panel: 手順 1、 1の画像 1
    • Loosen 8 T5 screws. They are all the same length.
  2. Dell XPS 9720 SSD Replacement, Loosen back panel: 手順 2、 1の画像 1
    • Use a spudger to pry the back panel off of the carbon fiber upper assembly. Slide it into the crack between the carbon-fiber and aluminum housings, and slide the tool around the perimeter of the device to release the plastic clips holding the two together.
  3. Dell XPS 9720 SSD Replacement, Unplug the battery: 手順 3、 2の画像 1 Dell XPS 9720 SSD Replacement, Unplug the battery: 手順 3、 2の画像 2
    • Insert your finger in the translucent loop, and pull straight away from the motherboard.
  4. Dell XPS 9720 SSD Replacement, Remove SSD retention screws: 手順 4、 2の画像 1 Dell XPS 9720 SSD Replacement, Remove SSD retention screws: 手順 4、 2の画像 2
    • Remove the 2 PH1 screws which retain the SSD and heat spreader. The innermost screw also retains the battery, you will have to gently lift the plastic battery mounting tab with your fingernail or a pry tool, allowing the copper heat spreader to be slid out from underneath.
    • The SSD is now free to spring up from the slot. Pull it in a straight line in the direction which it points at rest. Gently insert your replacement drive. Reverse the above steps to reassemble.
終わりに
作成者
3人の作成者と共同で作成されました。
Sebastien Bolle
メンバー登録日: 09/12/15
326 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 648
