メインコンテンツにスキップ
Dell XPS 7590 SSD Replacement
必要な工具と部品
  1. Dell XPS 7590 SSD Replacement, Flip laptop around: 手順 1、 1の画像 1
    • Flip your device the other way around
    • Don't be confused that this device is black, its a skin
  2. Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: 手順 2、 3の画像 1 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: 手順 2、 3の画像 2 Dell XPS 7590 SSD Replacement, Remove 10 Torx T5: 手順 2、 3の画像 3
    • Grab your T5 Torx and identify the 10 torx screws
    • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
    • Careful there are more screws, do not try to open yet!
  3. Dell XPS 7590 SSD Replacement, Remove Flap Screws: 手順 3、 1の画像 1
    • Open the flap on the back of the laptop
    • There are two screws that need to be removed, please use a Philips 0 screwdriver
  4. Dell XPS 7590 SSD Replacement, Remove Backplate: 手順 4、 1の画像 1
    • The backplate might not be easy to open
    • You can use a soft prytool to open the laptop easier
    • Don't insert the tool too deep or you might break the mainboard
    • Now, you should be able to remove the backplate
  5. Dell XPS 7590 SSD Replacement, Unplug Battery: 手順 5、 3の画像 1 Dell XPS 7590 SSD Replacement, Unplug Battery: 手順 5、 3の画像 2 Dell XPS 7590 SSD Replacement, Unplug Battery: 手順 5、 3の画像 3
    • Locate the battery connection to the mainboard
    • Unplug the battery before doing anything else
    • You can use a pry tool to make this easier
  6. Dell XPS 7590 SSD Replacement, Locate and remove SDD: 手順 6、 3の画像 1 Dell XPS 7590 SSD Replacement, Locate and remove SDD: 手順 6、 3の画像 2 Dell XPS 7590 SSD Replacement, Locate and remove SDD: 手順 6、 3の画像 3
    • Locate the SDD on the mainboard
    • Use a Philips 0 to remove the screw of the SDD
    • Slide the SSD out of its socket.
    • Try not to lift the SSD any more than necessary
    • During reassembly, make sure the slot in the SSD lines up with the slot in its socket. Do not touch the gold-colored contacts with your fingers.
    • Reconnect the battery and reassemble
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Max Lembke
メンバー登録日: 09/14/19
951 ポイント
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 49
今までの合計 3,906
