メインコンテンツにスキップ
Dell XPS 18 Wireless WLAN Card Replacement
必要な工具と部品
  1. Dell XPS 18 Wireless WLAN Card Replacement, Back Cover: 手順 1、 1の画像 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Wireless WLAN Card Replacement: 手順 2、 1の画像 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Wireless WLAN Card Replacement: 手順 3、 1の画像 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Wireless WLAN Card Replacement, Internal Cover: 手順 4、 1の画像 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Wireless WLAN Card Replacement: 手順 5、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 5、 2の画像 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Wireless WLAN Card Replacement: 手順 6、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 6、 2の画像 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: 手順 7、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: 手順 7、 2の画像 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Wireless WLAN Card Replacement: 手順 8、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 8、 2の画像 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Wireless WLAN Card Replacement: 手順 9、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 9、 2の画像 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card Wires: 手順 10、 1の画像 1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Wireless WLAN Card Replacement: 手順 11、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 11、 2の画像 2
    • Pull back the cables.
  12. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card: 手順 12、 1の画像 1
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  13. Dell XPS 18 Wireless WLAN Card Replacement: 手順 13、 2の画像 1 Dell XPS 18 Wireless WLAN Card Replacement: 手順 13、 2の画像 2
    • Angle the wireless WLAN card upward and remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Austin Weir
メンバー登録日: 01/31/15
1,287 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G29
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,435
